Thanks for the input. My internet cable comes from the street & phone (land line) are separate.
It makes sense to avoid going in the building. I'll ground the mast all the way to service panel.
According to your summary, you suggested to run the coax to within 10' of the service panel & use #10 ground wire to ground block. How would you ground the AMP/8-way splitter? It's 90' distance between Antenna & panel.
