As I recall, the Polson area is not heavily treed, though the surrounding area can be. If you have no trees blocking your line of sight toward the transmitters, then the smaller antenna may serve your needs well. If you have some trees to contend with, or are going to drive several TVs or long lengths of coax, the larger antenna will give you the benefit of added gain and a bit more rejection of multi-path inference.
