Old 30-Apr-2014, 8:44 AM   #3
For reception of , Canada , USA , Digital Broadcast Tv Stations/Channels install Above the Peak of the Roof in such a manner that the the roof and building are not , obstructing , impeding , blocking , reception reception in the directions of , East , South East , South , South West , both East.
Install a , Antennas Direct , DB8e , UHF antenna aimed at about 145 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
For reception of , CKCO , CTV , VHF high band channel 13 , install a , www.antennacraft.net , Y10-7-13 VHF high band antenna aimed at about 256 degree magnetic compass direction.
Install a , www.antennacraft.net , 10G221 preamp.
Connect the DB8e antenna to the UHF connection of the preamp.
Connect the Y10-7-13 antenna to the VHF connection of the preamp.
The FM radio interference trap will be in the , in/on position.
For 1Tv connected use No splitter.
www.hollandelectronics.com
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Measure around the chimney and use a , ronard(2213) , ronard(2218) , ronard(2224) .
www.ronard.com
www.saveandreplay.com
www.tdlcanada.ca
www.trentondistributors.com
