Old 30-Apr-2014, 7:13 AM   #3
For reception of Digital Broadcast Tv Stations/Channels in the , Green and Yellow Reception Zones.
The greatest number of Digital Broadcast Tv Stations are to the , North West , West , North , North East.
The Tv stations in those directions are strong to medim signal strength and are LOS=Line Of Sight Reception
A small antenna will receive them.
Above the Peak of the Roof install a , www.antennacraft.net ,
HBU11K antenna aimed at about 319 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
The Digital Broadcast Tv Stations/Channels to the , South South East , are even stronger signal strength and will be received through the back of the HBU11K antenna that is aimed to the North West.
A antenna system amplifier will not be required for , 1 , 2 , 3 , Tv's connected.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
www.amazon.com
The receivable Tv Stations are to the , North West , West , North East , South South East.
Install the HBU11K antenna Above the Peak of the Roof do that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of reception.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the the least amount to no amount of obstructions in the directions of reception including your own roof and building.
