Old 30-Apr-2014, 5:30 AM   #7
If more then 1 Tv is connected.
If the , power supply/power injector , is on the inside of the house and the power is to go to the preamp unit outside and the power is going through a splitter , then a power passing splitter must be used so the power can get out to the preamp unit.
That is why I recommended the HFS power passing splitters.
Other power passing splitters can also be used.
If a power passing splitter is not used , then the power supply/power injector must be connected before the splitter so that power can get to the preamp unit.
