It looks like KTMF carries ABC and Fox.
To keep things simple, one antenna, consider a Winegard HD7694P or Antennacraft HBU-33 pointed south (about 170° per a compass).
The signals from the north are receivable and you can swing the suggested antenna that direction to see if there is anything you're missing... I suspect there is a lot of repeated programing carried on low powered translator stations... But still, it would be good to know if you're missing out on something you would like to have. If you see a signal that you want from the north and can't get it reliably with the one antenna pointed south, then we can likely figure a way to add a UHF only antenna to the mix...
