Old 29-Apr-2014, 10:53 PM   #1
Charles
Bench Test RCA Preamp?
In the process of installing a first time OTA, I've run into problems. After several many times up and down the ladder, I have determined that one of the cables that came with my Antenna Direct DB8E was faulty. One problem solved. The other problem centers on the RCA TVPRAMPR-1R, it appears to be bad, is there a way to bench check it?
In addition to the Antenna Direct DB8Em my setup includes a Antenna Craft Y10-7-13, and the RCA Preamp is what was used to join the signals from both antennas to the tv input. While I figure out how to deal with the preamp, is there another widget that I can get to join the two antenna signals?
Thanks for any assistance with this!
Charles
TV-Fool Report: http://www.tvfool.com/?option=com_wr...5b94e4fe1556fe
Charles is offline   Reply With Quote
