Old 29-Apr-2014, 9:34 PM   #14
Tower Guy
I'd try the single antenna solution, it's less expensive and likely to produce good results. We can deal with an alternate two antenna solution if the need is proven.
That's good advice.
Yet to add WZZM is pretty easy. Get this channel 13 Jointenna for $3.99 before they run out. http://www.channelmasterstore.com/JO..._p/cm-0583.htm
Then aim a Y5-7-13 at WZZM and couple it to the 7-51 antenna.
