Old 29-Apr-2014, 6:34 PM   #12
If you need to add some length to an existing cable, the F-81 'barrel' connector can be used to join the new section of cable to the existing.
Example: http://www.cableandwireshop.com/holl...connector.html
As I scan down the list of real channels on your TV Fool report, WGVK (real CH-5) is the fist Low-VHF signal that I come to. It's quite weak, but if you want to try to receive it you could go attempt to with a Winegard HD7084P or Antennacraft HD1850.
I would caution against high expectations, there is more noise/interference present in the low band.
