Old 28-Apr-2014, 7:35 PM   #12
The Tv signals are being over amplified , Disconnect and Remove All Parts of the PA-18 Preamplifier , disconnect and remove the preamp unit , dis connect and remove the power injector/power supply.
A distribution amplifier is most likely not required.
Over amplifying signals will make reception worse.
Is the HBU11K antenna installed Above The Peak Of The Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , West , South South West ??
Your reception location has strong local WGAL signals on channel Real channel 49 at 286 degree magnetic compass direction and Real channel 8 at 216 degree magnetic compass direction.
The 240 degree magnetic compass starting antenna aim direction is the starting antenna aim direction.
The antenna aim direction is adjusted for best reception.
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The directions of reception at your location are , West , South South West.
WGAL has more then 1 transmitter for improved reception of WGAL signal.
The antenna aim and antenna location can adjusted for best reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
