A tuned filter type combiner that would allow you to insert one channel from an auxiliary antenna into the main feed from a primary antenna exists... tinlee.com still makes the AC7 and charges about $125 + tax + S&H.
You can try a common 2-way splitter connected in reverse... but there will be no filtering to prevent negative interactions between the two antennas or cancel the weak off aim reflected signals from one antenna that will behave as multipath interference to the other antenna. It works in some cases, but most folks have one or more problem channels as a result.
Reason: sp.
