Old 28-Apr-2014, 4:55 PM   #6
I agree with ADTech, that you'll be doing yourself a favor if you verify that the signal conditions at your actual location.
If the conditions don't change significantly, then I'd try just one antenna. If it turns out that the WZZM signal can't be received reliably after fine tuning the aim point, and WOTV is not an acceptable alternative for an ABC affiliate, then yes, a second antenna can be added. Let's not be too worried about that yet.
