Do you think because of the close proximity I will be able to pick up WZZM 13 with they antenna's you suggested pointed around 130? If not should a smaller sub antenna be installed on the mast to point the direction of 13?
Also how much signal loss is there with longer cables. I would need to run down the side of the house to the basement. to a splitter. Then run across the basement to my cable splitter and then part way back across and up to the living room tv. The family room tv is close to the first splitter.
