Old 28-Apr-2014, 6:51 AM   #3
A Simple Reception Situation.
The Current Plus Pending Applications Included Digital Tv Station Radar Plot and Channels List Tv Stations to the , South East and North East.
The main group of Tv stations is to the South East , some other Tv stations are to the North East.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , South East and North East.
Aim a , www.antennacraft.net , HBU44 antenna at about 128 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
Antenna system amplifier will most likely not be required for 1 or 2 Tv's connected.
Buy the HFS-2D splitter at , www.hollandelectronics.com , or , www.amazon.com
How many Tv's will be connected??
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com,ychim.html
Measure around the chimney and use a , ronard2212) , ronard(2218) , ronard(2224) .
Buy the ronard antenna mounts at , www.ronard.com
With the HBU44 antenna aimed to the , South East receiving the South East Group of Tv stations.
The Strong Signal Strength Tv Statins to the , North East.
Will Yes also be receive with No Antenna Rotation.
Antenna rotators Are Not channel surfing friendly , must wait for antenna to rotate.
Antenna rotation is not recording friendly.
And their -Will Be Domestic Situations- about the direction the antenna is aimed.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions in the directions of reception including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv/s Must Channel Scan for the , ATSC-Digital Broadcast Tv Ststions/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through Air from the transmitting antenna to the receiving antenna.
Some digital tv 's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select and channel scan for ATSC-Digital Broadcast Tv Channels.
Last edited by teleview; 28-Apr-2014 at 11:23 PM. Reason: Clarify information and typos.
