The information from your TV Fool report says the C2V should be doing well receiving KSPR, KOLR, KYTV, KOZL & KOZK if aimed correctly, facing about 55° per a compass. If your results are not improved by changes to aim, height or location then I would step up several notches in performance. Apparently there is some factor that TV fool has no way of knowing and as a result your TVFR may not accurately show the conditions you really face.
A few of options to consider, The Winegard HD7698P and either the Antennacraft HBU-44 or HBU-55. All of these antennas are considerably larger than your TV fool report would suggest.
