Old 27-Apr-2014, 11:12 PM   #22
I might edit step 3 as follows;
3. If reliable reception is not obtained from each antenna using the new, high quality coax to a single tuner without the use of a distribution amp/splitter or after readjusting aim, if that fails, try new antenna mounting locations , consider changing out that antenna after exhausting all reasonable options.
Your plan is correct to focus on establishing that there is reliable signal at the antennas. Once that's done, the rest of the plan can focus on on getting a good signal to each TV.
Please let us know how things progress.
