Old 26-Apr-2014, 6:44 PM   #3
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , West North West , West , West South West , South.
Install a Antennas Direct DB8e antenna.
Aim one panel at about , 289 degree magnetic compass direction.
Aim the other panel at about 259 degree magnetic compass direction.
Buy the DB8e antenna at , www.amazon.com
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
Install a , www.antennacraft.net , Y10-7-13 antenna aimed at about , 259 degree magnetic compass direction.
Install a , www.antennacraft.net , 10G221 preamplifier .
Connect the , DB8e , UHF antenna to the UHF connection of the preamp.
Connect the , Y10-7-13 , VHF high band antenna to the VHF connection of the preamp.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , www.hollandelectronics.com , or , www.amazon.com .
www.ronard.com/90991.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com
Home Depot has , 10 foot 6 inch lengths of 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , makes good antenna mast.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
Last edited by teleview; 26-Apr-2014 at 9:40 PM. Reason: Clarify information and typos.
