Thread: confused in Nh
Old 26-Apr-2014, 2:08 AM   #12
Remove the Stacker.
Above the Peak of the Roof install a , www.antennacraft.net ,
HD1800 All Channel antenna aimed at about 180 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html .
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
Here are some Above the Peak of the Roof antenna mounts.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com
Install the RCA TVPRAMPR1R preamp.
Operate the preamp in the single antenna mode.
For 3 Tv's connected use a , Holland Electronics , HFS-2D , 2 way splitter.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , www.hollandelectronics.com , or , www.amazon.com
To Prove Reception before any thing else is connected.
Connect a NEW Continues Length of coax from the HD1200 antenna direct to 1 Tv.
Last edited by teleview; 27-Apr-2014 at 7:15 AM. Reason: Clarify information and typos.
