I have used a zinc based rod to successfully 'solder' cast aluminum. I had had a couple of sample packs of assorted soldering and brazing rod lying around for years and finally had a need to try a repair on aluminum. I think I had bought the rod at a Fred Meyer store more than ten years ago.
Copper will be far easier to solder... clean it well, use the right flux and enough heat.
