Based on the path profile links in your TV Fool report, I'd use two antennas and a preamp with a built-in combiner.
Consider the Antennas Direct 91XG + Antennacraft Y10713 + RCA TVPRAMP1R.
You'll have a much better chance of success if you mount outdoors, clear of obstructions. Use a starting aim of about 270° to 275° (compass). If mounting on the same mast, put the 91XG at the top, and the Y10713 at least 3' below the bottom of the upper antenna. (That tends to rule out a 5' mast. If you have a Home Depot within range, they likely stock 10.5' chain-link fence top rail which has served me well in several installations.)
