The Radio Shack 4-way amp is questionable.
The Stacker has an upper and lower section joined by a flat ribbon cable... If it's too close to metal, it can possibly detune the antenna. The cable looks similar to the flat cable that is a part of a 75 to 300ohm balun but is a separate part on the Stacker.
