I'd be looking at the insulation in the attic to make sure there is no foil. It could be inside and visible or between the sheathing/roof deck and the siding or shingles.
You may simply try moving the antenna in the attic to find a "hot spot".
An amplifier is likely to make things worse. A small directional antenna (ANT-751 or HBU-11) is a better choice than the leaf clone.
