The reception situations that you and I both describe are the reasons for the recommending of and the use of a more directional antenna.
The -->only way<--to discover the degree that a more directional antenna will improve your reception situation is to install the CM4228HD.
DO NOT use a antenna system amplifier of any type or kind at you reception location.
The signal strengths are Strong at your reception location this means that the reflected signal strengths are Also Strong , making the reflected signal strengths that are causing the reception problems stronger will make reception worse.
Reason: Clarify information and typos.
