Old 21-Apr-2014, 3:05 AM   #4
huddlbud
Thanks mast and teleview.
My issue is very frustrating. Seems that weather has a major impact. When windy and/or rainy, the proble is much worse and spans multiple channels. The weather today is perfectly clear and almost zero wind. I sat scanning channels and the only channel that had any issue at all was channel 5.1. All of the other channels had no issue at all. Ironically, even in rainy/windy conditions, channel 8 seems to be one of the most stable and it is further away and in a direction that the antenna is not pointing.
Unfortunately there is no way that I can avoid trees where I live. There are many trees between my house and the direction of the transmission sources. Given this info, do you still feel it is advisable to purchase to channel master 4228hd antenna? Would you expect it to overcome these issues? I am only about 8 miles from the transmitters for the most part. Btw, I installed the suggested fm filter but ii can see no real impact. Can't hurt I guess.
Thanks for you help. Much appreciated.
huddlbud is offline   Reply With Quote
