Old 20-Apr-2014, 6:27 AM   #6
For less then all out maximum reception , of as many different digital broadcast tv stations and networks as possible.
Install 1 antenna in place of the DB8e and Y10-7-13 antennas.
Install a http://www.channelmasterstore.com.
CM4228HD antenna aimed at about 157 degree magnetic compass direction.
The CM4228HD will get you the major networks.
In place of the 10G221 , separate UHF/VHF antennas preamplifier.
install a , 10G201 , combined UHF/VHF antenna preamplifier , the reason is , the CM4228HD antenna is a combined antenna that receives both the UHF and VHF high band channels.
For reception of the major networks with less reliability of reception , install the CM4228HD antenna on the 5 foot pole 5 feet above ground.
For less reliability of reception , on the 5 foot pole 5 feet or less above ground , install a , Antenna Craft HBU11 antenna or ANT751 antenna.
For less reliability of reception , do not install a preamplifier.
And as always , you are free to choose and install a antenna of your choice and install the antenna at any location that you choose.
To help you decide , however not to tell you what to do , read the following.
Attics and the Inside of buildings Are Not a Reception Friendly Environment and Never Will Be a Reception Friendly Environment.
Last edited by teleview; 20-Apr-2014 at 8:06 PM. Reason: Clarify information and typos.
