Old 19-Apr-2014, 8:43 PM   #5
-->Many<--Digital Broadcast Tv Stations/Channels will be received at azimuth directions of 123 to 197 degree magnetic compass directions.
Antenna #1 , Antennas Direct , DB8e , UHF band antenna.
Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , 123 degree to 197 degree magnetic compass directions.
Install a , Antennas Direct - DB8e UHF channels antenna.
http://www.antennasdirect.com.
Aim 1 panel at about 147 degree magnetic compass direction.
Aim the other panel at about 180 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
Antenna #2 , Antenna Craft , Y10-7-13 , VHF high band antenna.
At the same location as the DB8e and about 3 feet below the DB8e on the same antenna mast install a ,
http://www.antennacraft.net
Y10-7-13 , VHF high band antenna aimed at about 169 degree magnetic compass direction.
Install a , AntennaCraft , 10G221 preamplifier.
Connect the DB8e antenna to the UHF connection of the preamplifier.
Connect the Y10-7-13 antenna to the VHF connection of the preamplifier.
The 10G221 preamplifier will be operated in the Separate antenna mode.
The FM radio interference trap of the preamplifier will be in the , in/on position.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Here are some places to buy antennas and etc.
http://www.antennacraft.net , http://www.antennacraft.com.
http://www.ronard.com.
Home Depot has , 10 foot 6 inch lengths of 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast pipe , the cost is low at about 10 dollars.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception with a Tv antenna in the directions of reception and so do buildings and other obstructions including your own roof and building in the directions of reception.
Absorbing and Blocking Tv Reception.
The Best Practice for Reliable Reception is to install antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tuners will Automatic channel scan for cable tv channels.
Do Not channel scan for only Analog tv channels.
Go into the Tv Setup Menu and select and scan for ~Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~.
Channel scan for ATSC-Digital Broadcast Tv Stations/Channels.
Last edited by teleview; 18-Jun-2014 at 1:53 AM. Reason: Clarify information and typos.
