Old 18-Apr-2014, 9:34 AM   #15
Stereocraig
Originally Posted by csaag View Post
Returning to HD isn't a problem & I've sold plenty on Ebay so that's not too much trouble
but on the bright side I've learned a bunch from all this so thanks for the info & recs.
BTW, with the larger antennas, would I have a problem getting them through the access panel into the attic?
That will depend on the size of the opening and the smallest dimension of the antenna.
Some antennas are shipped in in pieces, or folded up.
You may be unfolding, or assembling it in the attic.
This also means that you will need to fold it back up, or disassemble it to remove it, when you are unhappy w/ the results of an attic install.
