Old 18-Apr-2014, 5:16 AM   #9
I've not seen any major network affiliate expressing regret for their UHF assignment. I can't say the same for the few who chose a Low-VHF channel or were forced to accept one.
Regardless, the choice is not complex in this case. bart, if you want to get every possible signal then a large all channel antenna is indicated, and we've listed several valid options.
If your choice is to use a slightly smaller antenna and forgo one infomercial channel, then you have several good suggestions to look at.
Best regards
