Old 17-Apr-2014, 7:42 PM   #3
Obstructions in the directions of reception will disrupt reception.
Trees and tree leaves , plants and plant leaves , buildings and other obstructions including your own roof and building.
Some and not all disruptions are.
Absorbing and Blocking Reception.
Stationary multi-path reflections are bad.
Moving multi-path reflections caused by objects that move such as and not limited to , trees , vehicles , people , etc. , Are Worse.
The idea is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the direction of reception.
A more directional antenna can help with reception.
A more directional antenna can help with reduction interfering multi-path signals bouncing in from other directions.
Install a , Channel Master , CM4228HD antenna aimed at about 244 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
Also coax can be defective even though the coax 'looks good'.
As a Test to prove reception , install a NEW Continues Length of Coax to the CM4228HD antenna and run the New Continues Length of Coax through a open door or window direct to 1 Tv.
Digital Tv Tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf.
Last edited by teleview; 9-May-2014 at 6:44 AM. Reason: Clarify information and typos.
