If you opt for an antenna that omits support for real CH-2 through CH-6, you get less wind load and a bit slimmer profile. You also give up any reasonable chance at receiving KHFW-LD, real CH-4, an Hispanic religious station that is not currently on the air (per rabbitears.info) or KSFW-LD, real CH-2, an infomercial broadcaster.
If you want to go this route, the Antennacraft HBU-44, HBU-55 or Winegard HD7698P come to mind.
