Old 17-Apr-2014, 12:26 PM   #1
tonyvalentine
Another recommendation for another newcomer please.
I'm ready to cut the cord like so many others and would appreciate some input on how to go about this. Right now I have DTV on a 5' pole on the southeast side of my home which is on top of a mountain in upstate NY. I would like to use the existing pole if possible along with existing cable for up to 6 tv's. However I only use 3 at the moment.
I filled out the signal analysis http://www.tvfool.com/?option=com_wr...5b944b63de9e8f and it looks like I'll be able to get all the networks with the current spot and would like any recommendation for a particular antenna and other equipment needed. The less obtrusive the better but obviously if necessary a bigger antenna will have to do. I'll be pointing through a clearing with some trees about 85' away on the other side.
Thanks for any help you can provide.
Tony
tonyvalentine is offline   Reply With Quote
