Old 17-Apr-2014, 2:59 AM   #1
bart
antenna assitance needed in East Texas
**http://www.tvfool.com/?option=com_wr...5b94bdd092b854
First thank you for any assistance you provide me with, I would have made what is apparently a poor choice if I had not found this forum. I was planning to follow my fathers purchase of a Lava amplified antenna since he has had good results with it, but I would rather buy something that will last.
As far as the report I would like to be able to pick up the stations in the 70 - 116 degree range, but I am not sure if that wide of a range/distance is even possible. Alternately I want to be able to add a motor to rotate the antenna at a later date for the stations in the 287 - 306 degree range if possible.
I would also like to ask if the RCA ant3036w would be a good choice for this application. It is available at a local wal-mart, so if there were an issue it would make for an easy resolution.
Thank you in advance,
Bart
bart is offline   Reply With Quote
