Old 17-Apr-2014, 12:14 AM   #12
The antenna will be in the horizontal plane , flat with the ground.
You can install the antenna on the side of the pole that is in the direction that the picture is looking at.
The point is , to avoid installing the antenna at locations that the reception will be more obstructed.
That apartment building that is in the direction of the picture is looking at is disrupting reception.
Home Depot has , 10 foot 6 inch lengths , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast to get the antenna up higher.
The 1 and 3/8 inch diameter pipe will most likely fit inside the satellite mount pipe.
