Antennas are the Device that Actually Receive the Signal.
The Bigger the Antenna the More Signal is Received.
The more signal is received by the antenna at good reception location/s the better and more stable the reception will be.
Amplifiers Do Not receive signal and amplifiers will not correct bad reception.
Amplifiers will not correct bad reception caused buy bad reception locations.
Amplifiers will amplify bad reception along with the good reception.
Going to great lengths to find the easy way out is a good way to have bad reception.
And the -easy way- becomes the --> Least Easy Way.
If you must have the antenna in the attic , then use the Antenna Craft HD850 antenna.
The antenna and any coaxes that are used for the antenna system Must Not be connected to any coax that has any type or kind of active cable Tv delivered services , be it , cable Tv service , cable internet service , cable phone service , or any other type or kind of cable service.
Some satellite systems will accept and distribute the tv antenna reception and some satellite systems Will Not.
Check with a satellite system installer to see if the satellite system will or not.
Even so , the best practice to avoid problems is to not connect the Tv antenna and satellite system on to the same coaxes.
Reason: Clarify information and typos.
