I'm concerned about the potential trouble due to the signal blocking quality of aluminum siding. An attic installation is going to reduce your opportunity for reliable reception. Just how much impairment can't be determined except by trying an installation in the attic.
Most of the available signals are UHF frequencies. An Antennas Direct DB8E can be adjusted to have a fairly wide reception pattern. With one panel of the DB8E facing about 295° and the other facing about 330° you can expect a mix of both US and Canadian signals.
The signal from WBBZ can be received with the addition of an Antennacraft Y10713. You would also need a UHF/VHF combiner with this option.
