Old 16-Apr-2014, 6:55 PM   #4
The Current Tv Channels that are being Transmitted and Received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your reception location Currently has receivable Tv channels in the , VHF high band and UHF band.
Look at the Green and Yellow reception zones of the Current Plus Pending Applications Included Channel List and Radar Report.
Look at the Channel List and see the ==Channels== , Real and (vert) virtual numbers.
Real channels are what is/are Transmitted and Received.
Real channels are what are received by a Tv antenna.
(virt) virtual numbers are Not Real Channels even if the (virt) number is the same as the Real Channel.
Tv Antennas Receive Real Channels.
The DB8e and SC4 are UHF channel designs.
The HBU33 is a VHF high band channels and UHF band channels design.
Tv antennas such as and not limited to the HBU33 antenna receive the best in the forward direction , the forward direction is the direction the antenna is aimed.
Here is how to aim antennas , http://www.kyers.com/antenna/pointing/pointing.html.
Directional antennas such as and not limited to the HBU33 antenna also receive a little less at front angles to the antenna
Less at back angles the the antenna
Less at the back of the antenna
And receive the least amount of signal directly on the sides of the antenna.
If a picture of the HBU33 antenna is placed on the Tvfool radar map and the antenna is aimed at the weaker tv stations to the South West , at 230 degree magnetic compass direction.
You will see that Many More Tv Stations and Channels will be received because the HBU33 antenna is aimed at the Weaker signal strength Tv stations and the Stronger signal strength Tv Stations and Channels to the West and North West will be received at angles to the HBU33 antenna.
Because the Tv stations to the South West are weaker signal strength the UBH33 antenna will be installed Above the Peak of the Roof so that the reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , South West , West , North West , North , North East.
A antenna system amplifier will most likely not be required.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
For 4 Tv's connected use a 4 way splitter.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to Install the HBU33 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building in the directions of reception.
