Old 16-Apr-2014, 3:42 AM   #1
huddlbud
Need reception help in Atlanta
I have installed an RCA ANT751 antenna on my roof and have aimed it to 244 degrees. No amps of any type. I have around 50' of rg6 coax going to my tv. The reception I am getting is very inconsistent. It will show almost full bars on the strength meter and then it will drop down to the red and the bounce back up to strong and then sometimes drop to no signal and I will lose the channel completely. After a few seconds, it will come back, usually very strong and then start all over again. That being said, I have also seen it be consistently strong for extended periods but it is rare. I am only 7.5 miles from most broadcast antennas so it would seem that I should be getting excellent, consistent reception. But I am not. Below is the link to my report. Any suggestions would be appreciated. Would like to dump DirecTV but that's not going to be possible if I can't fix this.
http://www.tvfool.com/?option=com_wr...5b94f0aca34a0a
Thanks!
huddlbud is offline   Reply With Quote
