Old 16-Apr-2014, 12:55 AM   #2
Could someone have started using a new device that is messing with the audio signal only?
No. The audio is not distinguishable from the video except at the data level. It is not possible for external interference to affect only the audio portion of the broadcast before it get demodulated in the tuner.
Whatever the issue might be, it's unique to your hardware, probably the TV set itself or its input port that you are using with the converter box.
