Old 4-Dec-2010, 7:17 PM   #15
mutton-javelin
That DB4 sounds good. I have no idea what the antenna is in the free offer. I was told it was UHF and he is sure it is.
As far as grounding. If I run the antenna cable to the splitter on the side of the house. Is this sufficient or do I need a separate copper wire from the antenna.
I have cable tv service from the pole to the side of the house. There is a splitter with a copper wire to a new ground rod right below it. Does this cover it, or do I need a copper wire from the antenna to that ground rod. Also, can I use the same ground rod or do I need a new one. I figured I would run the wire from the antenna to the splitter on the side of the house and use the existing cable inside. (2 outlets) So perhaps a pre-amp as well?
mutton-javelin is offline   Reply With Quote
