Old 15-Apr-2014, 4:45 PM   #4
tomfoolery
That's in addition to the one you're using, not to replace it. But if you only have room for one antenna on your mast, consider one designed for both H-VHF (channels 7-13) plus UHF reception. Since what you have is working to your satisfaction, if it were me, I'd add a VHF antenna, which then also gives you the flexibility to aim it independent of the existing for best reception of the target station. If you don't have the room, then that's another story. It's only $24 at Solid Signal and other places, though I don't know what shipping is. Also need a UVSJ to combine the VHF with the UHF so they don't interfere with each other (from $2 to $10, depending on where you get it), but there are more weather proof types (more money) available if you don't want to seal it up against the weather yourself.
tomfoolery is offline   Reply With Quote
