Old 14-Apr-2014, 9:10 AM   #9
Install the CM3671 antenna above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , North East , West South West.
Aim the CM3671 antenna at about 50 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
Install a CM7778 preamplifier.
http://www.channelmasterstore.com.
http://www.amazon.com.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
http://www.ronard.com.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
Multi-Path reflecting Tv Signals Bouncing All Around.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv/s Must Channel Scan for the , ATSC-Digital Broadcast Tv Stations/Channels.
Often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu Because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
DO NOT channel scan for only Analog tv channels.
Go into the Tv Setup Menu and select and channel scan for the , ATSC-Digital Broadcast Tv Stations/Channels.
