Old 13-Apr-2014, 6:08 PM   #29
dmfdmf
Originally Posted by teleview View Post
dmfdmf , is asking questions that are in the original posts , this goes to the original posts.
It looks like the thread has been consolidated, thanks teleview.
bwag32, I think you need to slow down and do some troubleshooting per teleview's post #21. Your signal for Fox is weak but not that weak, so your antenna and amplifier system should be fine to drive two TVs. Do you get RCH23/CW or RCH36/ION? These stations are weaker than Fox according to your TV Fool report and if Fox is the only station knocked out by the splitter something weird is going on.
I would start over and rebuild the system one step at a time, retesting along the way to find the cause. If you get Fox at the antenna with no pre-amp and a direct line to one TV with 50ft or less of coax then that is step one to prove you have signal at the antenna to amplify. Everything follows from that.
dmfdmf is offline   Reply With Quote
