Tv Reception
410 bando road is down in a valley the surrounding mountains are blocking the tv transmissions. Go to the >>StartMaps<< part of tvfool and put in your address , select current plus pending stations , raise the antenna height to 500 feet and click on the white circles next to the stations call letters to get the area where you live to ' light up' with the colored signal strength. Now lower the antenna height and you will see what can be received at different lower antenna heights.
