Old 12-Apr-2014, 7:51 PM   #10
In an attic I've use thin wall electrical conduit. I simply drilled a couple of holes through, near the end of the tube and used screws to attach to a rafter. The tube then hung from the top. I've even used nylon twine to hang the antenna, but adjusting aim is cumbersome.
Wood dowel or plastic pipe is also an option.
Some folks prefer a store bought solution. The J-pole used for many satellite dish installs can be used. It can be hung from above if that works in your application.
If we were neighbors, you'd see an HBU-44 or equivalent combinations of UHF +VHF antennas above my roof.
