Old 12-Apr-2014, 4:36 PM   #8
The main groups of Tv transmitters are to the , North and North East.
Aim 1 panel of the DB8e at about 20 degree magnetic compass direction.
Aim the other panel at about 68 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
W11DD-D is a repeater transmitter , Georgia PBS.
If W11DD-D , Real VHF high band channel 11 , Georgia PBS is not being received and you will like to receive it.
http://en.wikipedia.org/wiki/WCES-TV.
Then install a , http://www.antennacraft.com.
Y5-7-13 antenna aimed at about 242 degree magnetic compass direction.
Install a , http://www.antennacraft.com.
10G221 preamplifier.
Operate the 10G221 preamp in the Separate UHF/VHF antennas mode.
Connect the DB8e UHF antenna to the UHF connection of the preamp.
Connect the Y5-7-13 antenna to the VHF connection of the preamp.
The FM radio interference trap of the preamp will be in the , in/on position.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.amazon.com , or , http://www.hollandelectronics.com
Digital Tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf.
