Also, FWIW, here's the current readings im getting off of my HD Home Run with the amp in the basement:
Channel 12 - 73% Strengh, 73% Signal Quality, 100% symbol quality
Channel 24 - 57% Strength, 55% Signal Quality, 100% symbol quality
Channel 29 - 55% Strength, 54% Signal Quality, 100% symbol quality
Channel 44 - 65% Strength, 62% Signal Quality, 100% symbol quality
Channel 51 - 59% Strength, 64% Signal Quality, 100% symbol quality
The antenna is just currently laying in the attic ontop of the insulation and I'm sure it isn't aimed close enough. When I lift the antenna up by hand about four feet other stations come in and the percentages go up quite a bit more.
