HLSJ = High VHF channels 7 thru 13 / Low VHF channels 2 thru 6.
Seperator / Joiner.
Used to combine VHF high band and VHF low band antennas.
UVSJ = UHF channels 14 thru 51 / VHF channels 2 thru 13.
Separator / Joiner.
UVSJ , is used to combine UHF and VHF antenna.
When using the the UVSJ and HLSJ the coaxes Do Not need to be the same lengths from the antennas to the UVSJ , HLSJ .
For your reception situation use the UVSJ.
Connect the C2v to the UHF connection of the UVSJ.
Connect the Y5 to the VHF connection of the UVSJ.
Reason: Clarify information and typos.
