Old 9-Apr-2014, 9:07 PM   #23
You have several options. The chain-link top rail is swedged so that sections can be stacked end to end. That will require the use of guy-wires or wall brackets.
http://www.3starinc.com/adjustable_3...enna_mast.html
http://www.3starinc.com/wall_mounts.html
You can also consider using metal electrical conduit, rigid or IMC which will be threaded on both ends. It too would need to be supported similar to the top rail product.
