Thread: Heyburn, Idaho
Old 9-Apr-2014, 12:28 AM   #6
To receive the Networks , and more.
NBC.
ABC.
CBS.
PBS , PBS Create , PBS World.
FOX.
MyNetwork.
CW and CW+.
This Tv.
RTV = Retro Tv Network.
Telemundo.
Will require a Antenna that can be aimed in two directions.
The antenna is a , Antennas Direct DB8e UHF antenna.
Above the Peak of the Roof install the DB8e so that 1 panel is aimed at about 127 degree magnetic compass direction.
Aim the other panel at about 227 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antennas , do not trust a cell phone compass.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Home Depot has 10 foot 6 inch , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE. that makes good antenna mast pipe , the price is low at about 10 dollars.
Install a , http://www.antennacraft.com.
10G201 preamplifier.
The FM radio interference trap of the preamp will be in the , in/on position.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D and HFS-3D and HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
As always , the closer trees and other obstructions are in the directions of reception , the more disrupted reception will be.
As always , the more distant trees and other obstructions are in the directions of reception the better reception will be.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions in the directions of reception including your own roof and house.
Last edited by teleview; 9-Apr-2014 at 8:34 PM. Reason: Clarify information and typos.
