Old 28-Jan-2010, 2:04 PM   #14
fritzel67
Latest Update 1/28/10
Hello again,
I just wanted to follow-up one more time and say I FINALLY managed to get WNPT (PBS) in perfectly 100% of the time. I had already moved my Terk HDTVo outside at approx 12ft off the ground. The recommended direction to aim the antenna for this channel is 16 degrees magnetic north. I have a large hill directly in front of my house which is precisely where 16 degrees points to. By adjusting the antenna to more like 20-22 degrees (just to the right of the hill) the signal strength went from weak to upper normal.
So for others who are having signal strength problems, try experimenting just a bit outside the recommended azimuth settings.
fritzel67 is offline   Reply With Quote
